Any turbo ls knowledge?
A. Stock Lbz
Aug 13, 2013
342
spokane wa
Can get a good set of Deka 80s for like $300. would rather spend a bit more money and get a solid product.
I agree. But if you are doing a stock bottom end, China turbo, on a budget and get the injectors for free might as well decapp and go. If you are doing a nice build with some quality parts, buy some good injectors
NC-smokinlmm
<<<Future tuna killer
May 29, 2011
5,214
364
At Da Beach
. If you are running 93 you will blow out the main bearings before you run out of fuel...[TE]
Please explain this.
The weak link is going to be bearings in a stock gen 4 motor, start worring about mains over 600 rwhp especially if the motor is in a heavy truck with big tires. I was referring to 93 bc if you want to run e85 you will need larger injectors than if just running 93. 600 rwhp isn't a problem on 93 with 6.2 flex fuel injectors so there you go.:hug:
AZlml
278
32
Goodyear, AZ
Svo 42# can be picked up for dirt cheap if you're staying NA. As mentioned the deka 80# would be plenty for a stock bottom end with a turbo.
