Any turbo ls knowledge?
clrussell
pro-procrastinator
Sep 23, 2013
5,928
399
Does anyone have good turbo ls knowledge? 6.0 4l80 thinking about cam, turbo, springs and minor trans work.
Boat tow rig and daily driver
coker6365
Coker6303's ***** Daddy
Dec 4, 2011
486
If the tuning and cooling is right, it should tow fine on a moderate tune. How big of a turbo and what are the hp goals?
Sent from my SM-G930V using Tapatalk
clrussell
pro-procrastinator
Sep 23, 2013
5,928
399
No goals in mind. I ready 475s work well on 6.0s and they are readily available and cheap
coker6365
Dec 4, 2011
486
472/475/480 etc all work well with the right exhaust housing on a 6.0. A 472/83/.90 T4 would spool great and make 700hp. Fueling and oil temps will be the most important factor to keep it alive towing. A good tune will have safety factors built in to keep it from leaning out if any part of the system fails.
We are running a 480/96/1.0 T4 on a forged 408 right now and it spools excellent from 2200rpms and up. The exhaust side is the limiting factor but it should be an easy 800hp. Need to bump up to a T6 96mm turbine for more than that.
hondarider552
Getting faster
May 28, 2008
10,627
Arizona
I don't know wtf Im doing with this turbo LS stuff so can't help :roflmao:
My turbo is a 88/96/1.32 and gunna see how far it will take the truck. Have no doubt it will go 9s
coker6365
Dec 4, 2011
486
Sounds like a party! Lol. I have been trying to get my buddy here to throw a 488 on his 408 but he is scared of it.
LBZ1991
Nov 21, 2014
215
Winfield, MO
I'd really like to try the turbo is stuff. My new neighbor that I just met yesterday told me I could have his extended cab silverado, so that might be a sign lol
5,813
You will tax the cooling system quickly and 4th gear will be an issue if you try to use any of that power while towing. Trans will need a good build unless you keep it in 3rd under power pulling hills. We ran a whipple supercharger on my moms 98 cc/lb 454 GMC. Truck was lifted on 35s and towed a 35ft Alfa toy hauler and a 40ft weekend worrier. Had 75k on it when we sold it and a stock 4l80 but my dad never overly abused the truck when towing. Would always kick it to 3rd on hills and was always worried about breaking something so never really wooded it. Only time I remember was in pismo beach when we had to make a loop up into the soft sand. 30psi in the back tires, 25 in front and trailer down to 20 on all 6. 4 low 3rd gear, that motor and super charger sung a beautiful tune. We were the only truck of the camp to make the turn without getting stuck lol. Truck made somewhere in the 400-450 range on a cool day.
If you are smart with it, I see no reason it will tow just fine. Just still won't be like a dmax and an Allison. That said, you know I'd build it and try to make it work :D
clrussell
pro-procrastinator
Sep 23, 2013
5,928
399
The rig I have now is a 200k Yukon Denali that's mint and I picked it up for a song. I ran across a 6.0 for a steal and the same on the 80e.. this thing runs damn good as is. But waking it up another 100hp would be tits.
Hell maybenill just cam springs and tune the motor that in it and run it till the trans or engine shits out
zakkb787
<that’s not me...
Sep 29, 2014
2,340
Granite Falls NC
From what I hear a black bear tune makes an LS a whole new animal
