wouldnt hurt to try, you might try a lbz flow rate table, thats what i'm using, its just slightly more aggressive than the dealer fix for it.
theres several tables to change to ensure the egr is turned off, you should get rid of the code eliminator though and use efi to get rid of the codes/shut the egr off....................or you could just pull the whole egr system offin the tune egr is off would that make a diff???
Don't take the plate out of the EGR. Take off the "false code shuteruper!" You can tune out the codes with EFI. The fooler might be causing your problems. Did the problem start right after installing the new mouthpiece?
no i have not the the map is still in the stock location and in the same ID of pipe stock was i didnt think you had to rescale it unless you went to a bigger ID in the same location as the sensor ?????
Check B0734. That is the Engine Protection Mode that your truck will go into with the "hidden code" Pat was talking about.
