ok, i was driving home the other day parked the truck and everything was fine . the next day truck felt like it didn't have the power on the top end. logged the truck and the truck will only hit 74-77mm3 every thing is fine till you hit 77mm3 then the truck falls to 74mm3 and thats all i get!!!rail pressure hits 23-24k not hitting commanded rail pressure and not flowing commanded flow rate
changed the lift pump and same thing happens -bottle tested the rail no prob there. I dont think its the cp3 its got about 30k miles on it but i could be wrong its on a newer fuel filter (mabey 1k miles on the filter). about to change FPR but before I spend the money thought i would ask mabey someone has had the same problem? truck has 83000k miles on it.
any help would be great !!!!
thanks
kreig
thanks
kreig
