another Range Shift Inhibited
73impala
Nov 22, 2010
having a problem with this already replaced the ignition switch and NSBU switch and nothing worked. code reader is giving me P0700, P0841, P0843, and P0848. ive heard it could be a valve in the torque converter and also heard it could be a ground problem. the time that this started occurring is right after i did my body lift. so what are the grounds for the allison transmission that could cause this to happen? i have checked all the grounds that went along with the body lift and have gotten no results
thanks
Zcar
run it in the ground
I'm having the same problem. Did you ever get it figured out? I replaced the same two things. It seemed to be fixed after I replaced the ignition switch a little less than a year ago. Went out today and it came on again, I'm ready to let the thing roll down a large hill with no end. It is about 5 degrees outside, could this have anything to do with it? Its been having signs the last couple months that something was wrong. Twice I drove to the end of my driveway and hit the gas pedal, it rev'd up then slammed into gear to pull out. But then cleared up. I'm at a loss for this truck, something breaks on it once a month.
