I recently had the dealer tell me my 04 LB7 needs head gaskets. They said it had too much pressure in the rad hose. It runs great and I dont lose any coolant. A mechanic friend of mine did injector cups and a compression test for me just recently. 400 psi on all 8. Plus he said he pressurized the cooling system with the glow plugs out and didn't lose any coolant or pressure after he did the cups? Is the dealer out to lunch? If the cap is rated for 15psi, wouldn't compression gasses exceed that causing me to lose coolant out the overflow? I also noticed it's been running colder than usual since injector cups. Thoughts?
