henry, is there a kit that has pretty much everything you need to rebuild a motor? i know alot is RTV and then you have all the reuseable ones. but what about everything else? thanks
I will get something worked up for you do you want all the freeze plugs for the block and heads also and only the o ring and gaskets that I would replace or everything that should be replaced and you can mark off what you dont want ?
