Another Broken Crank
5,933
I asked him what he used and should I use the screw in. This is what he said..
Oem factory. Never use thread in. Waste of time and money, ran 150+psi of oil on factory freeze plugs, no leaks
thats fine if thats what they suggest. many ways to skin a cat here, all im giving is personal preference.
Bdsankey
4,225
1,330
Larsen, Wisconsin
correct on where and correct on what you will most likely be told. its not crucial to have done, its just small things like this i like to do or add. if its a small fee, i would add them for piece of mind. if they are talking 4-500 bucks, just put freeze plugs back in.
if you are running high rpm, high volume pump and 20w-50 oil, this is where i would very much recommend putting in threaded plugs.
Agreed. My local machine shop charges $4.10 per my last invoice (making them $1.03 per plug) for all 4 plugs and charges $75 labor to tap the block and R&R cam bearings making them a no brainer there at least.
OleBlackyLBZ
353
85
I'm going to let him do it how he prefers, but if there was even a slight possibility I was going to spin more rpm's and run race oil down the road I wouldn't hesitate. Either way thanks for the input, it's something I didn't know so I learned a little more.
Reactions: Bdsankey
13,736
806
You only made it 3 months on a built motor? That sucks, what happened?
Broke a piston. Keep in mind the motor was built way back in 2009 when the only piston options were cut/coated LB7 pistons or forged pistons that were not recommended for regular street use. I was close to 1000 hp with my truck, and the cut/coated stock pistons just couldn't deal with it.
PureHybrid
Isuzu Shakes IT
Feb 15, 2012
3,517
501
Central OH
Speaking of pistons, anyone have experience with the KB replacements for the Duramax? They have 16.8:1, 17.5:1, and stock compression height or -.010". Doesn't look like they have a "delipped" bowl as the Mahle, but they're cheaper than stock LB7s, and retain the pin offset
OleBlackyLBZ
353
85
So im needing to buy a complete gasket kit, does anyone know which gasket thickness I should get? And who has the best price on a complete gasket kit
1,971
If he's still around, get with Henry at Creatures of the Night performance. (S/V) He's usually has the best prices on things like that.
S Phinney
4,008
Quncy, Fl
Things that I recommend are if you are building a engine don’t use stock parts. They are only designed to do so much. I would not run a stock crack, rods, pistons , springs or pushrods. People keep pushing the limits and finding the limits and because your friend had good luck with stock parts doesn’t really mean anything. I recommend upgrading anything that you can afford to do and believe me if you can afford to do it twice you can afford to do it right once.
Reactions: Bdsankey
Bdsankey
4,225
1,330
Larsen, Wisconsin
The ideal method is to measure piston protrusion and buy the gasket that is correct for that protrusion. If you went with motorsport pistons, they already have 0.010 removed from compression height so they usually use a thinner gasket. I would either ask DHD to tell you what gasket you need or measure protrusion yourself. Most guys run a "C" thickness gasket by default as it makes it zero measuring effort and the truck still runs good but the proper way is to measure protrusion.
I also have extremely competitive prices on gasket sets, let me know if I can help get you squared away.
OleBlackyLBZ
353
85
I agree with you but money is usually the problem, my way of looking at it is if your going to upgrade every single part in the engine then you might as well throw a socal billet crank in there, by then your $20,000+ deep in an engine not counting fuel/air/trans to get the good out of that engine. Or you can spend $7,000 on a budget build and keep it 600-650hp and it should be about as reliable as that $20,000 engine at 1,200hp and probably even more so. It all depends on your goals, I don't know nearly as much as a lot of you guys but that's just my opinion. I feel like I would have been super happy with my first budget build had I used a new crank and had someone build it that I knew for sure could build one to last.
Bdsankey
4,225
1,330
Larsen, Wisconsin
To be fair, we have zero evidence (unless I missed a smoking gun somewhere) that they did anything wrong.
OleBlackyLBZ
353
85
I'm not saying he for sure messed mine up at all. All I'm saying is I'm not 100% for sure he knows what he is doing but this time around I have absolutely zero doubts about the worksmanship. With another truck in the same shop with another low mileage engine from the same place and low oil pressure I have my doubts. I have another cousin with a near fully built engine from them with about 10,000 miles on it so time will tell. He is currently only running about 550hp on it. The guy working on the low oil pressure engine said he has went over it several times and can't find anything wrong, he is starting to think bearing clearances are off and it's jacking with the oil pressure. Does this seem likely?
OleBlackyLBZ
353
85
Well this is interesting. I got a call from my cousin a few minutes ago that has the built motor from XCalibur. He went it alot deeper than me. Socals street rods, socal damper, springs pushrods, fingers pistons, new callies crank and socal af cam, arp main and head studs the whole 9 yards. And his truck just started doin the exact same thing mine was. We are almost certain its a another broken crank... never thought ours would break this close together. Mine had 28K on it, his has 30K he said. Should know more soon
1,971
I'm still falling on the "they didn't properly balance the rotating assembly" side of things.
OleBlackyLBZ
353
85
I agree 100%, that's what I've been thinking the whole time but that's hard to prove like bsankey says. I do know enough to know that they will never touch my truck again and I DO NOT reccomend them to anyone. Spend the extra couple thousand and get someone you have 100% confidence in.
