Yeah, I had a CM4130 10pt. cage custom bent up! The whole cage weighs less then 100lb.
Whats with the 1/2 round square tubing welded to the frame?
Did you find the specs somewhere on the cage or did you measure and have someone else bend?
I have a hydro bender and all dies ya know, you could just picked it up on friday and caged 2 trucks :angel:
I see you've capped off the end of the frame rails, where are you mounting your (I ASSume coil over) springs? And what's holding up the bed?
