On the Garrett turbos the brass fittings for the water lines are they specially made for the turbo. Can I put AN on instead to make it look cleaner? The inner diameter of the fitting is small so I dont know if I can just change it out.
Also for the oil drain I heard someone makes a fitting so I can use hose instead of the drain tube????
