Log? Does the truck smoke when you get on the throttle?
You might need to re-scale the MAF for the new piping. I presume the MAF is now located in front of the atmospheric charger, which probably has a larger diameter pipe than the stock intake? That would cause a (false) low MAF reading, which would restrict fueling.
Or do you mean literally nothing happens, like it just idles, even in park at WOT? If that is the case, there might be a problem with the accelerator pedal reading. You will want to log the various APP PIDs and make sure they are reading reasonably. You should see the throttle position move smoothly and linearly from 0% to 100% as you press down on the gas. You can do this log key on engine off if you prefer.
