so ive got a 2007 silverado 2500hd lbz duramax.
so it all started, i hooked up my sub to my battery, and the stereo and ground.
started my truck to pull out of the shop and BOOM abs light and park brake light are both one.
found a code for brake circuit so i tried by replacing the brake switch and it made no difference..
noticed that with the scanner hooked up it said brake switch (not applied) but cruise control cancel or something along those lines on tech II (applied)
doing my research online i see about a bad ground with the abs and bmc by the body mount. i remove that and clean it, re install. no difference.
check the ecm relay and try putting a different relay in that same spot.
this time i go look and the abs like is VERY VERY dim, and the display says check washer fluid, i have no turn signals, and no a/c.:angry5:.. and to top that off the tach reads 0 and will randomly bounce around 700rpm.
tried swapping relays back and now ive still got the same symptoms, no a/c and such.
i noticed if i drive the truck with that abs light being very dim, after about 2mph it starts flashing and seems to get brighter and faster as speed increases, and the tach bounces more.
i found on this forum someone else had a problem with there ecm relay and that caused almost identical symptoms but havent worked for me..
any help would be awesome.. im stumped
