Anyone else with a leveling kit (torsions bar bolts at 11 threads still showing), have issues getting their caster and camber within spec? Mine is significantly out. Toe is no problem, but I can't get caster and camber anywhere near the stock specs. The pins on those outside rings (on the nut side of the upper control arms) max out before I get close. Talking -2.9 degrees on caster and -1.8 degrees on camber if I remember correctly.
Any ideas?
Any ideas?
