Airdog2 or Fass
Alligator
Nov 9, 2006
1,919
N. Idaho
The Airdog and the FASS are both flow through. But the likely hood of the pump going out is very small, they have both been proven to be very well put together. I have had failures with both pumps though.
I have the FASS pump only, and it will flow enough to be able to drive down the road 1 mile from the house, and only gave me problems when I went over 2000 rpm's. I just did it today with my FASS HPFP w/o filters, and I could only tell when it started chugging, flipped the switch and all was good. They are not supposed to flow through at all.
ripmf666
15,123
14
47
Wentzville Mo
I would not want to run my truck that way its just working the Cp3 harder pulling thru it.I leave mine run when ever the trucks running.
Alligator
Nov 9, 2006
1,919
N. Idaho
I know that Henry, I was loading a tune and turned the pump off. I forgot to turn it back on when I left in a hurry, but it did flow through enough to make me positive I could limp the truck off the highway to safety if I need to.
ripmf666
15,123
14
47
Wentzville Mo
Chad I did not mean that to sound rude buddy.and yes its nice to know you could get to a safe area or even home if needed.But for the others reading they should not make a habit out of doing thing and install a bypass when they do not want to run there pump.for me I will just leave it on.I have done the same unhooked the pump and found out soon as I got into her some.:hug:
Alligator
Nov 9, 2006
1,919
N. Idaho
It's all good Henry, the internet makes things sound funny...:hug:
ripmf666
15,123
14
47
Wentzville Mo
You can say that again lol :hug:
I would love to get both pumps and cut them like the pic I posted and see if ea really look like that.You see info that Fass gives you to help sales and you see info that AirDog has and there all never the same.I would like to see it first hand.If the pic's are the same that I posted to me the Fass is alot cleaner built pump and looks to be built better.I do not run one I run a PPE lift pump but i do sell both.I might try a Fass out I also have a Weldon 2035 race pump from my race car I would like to try.
stacks04
792
Terryville,Ct
i have the ad. it is really not that loud. much quieter than the fass imo. i have mine wired to a switch to shut it down when i get to low on fuel just in case and have run no problems using a pass through. i will have to hook my vacuum gauge on it to see what kinda vacuum it pulls that way. then we know for sure how bad it potentially could be for the cp3. but like chad i sometimes forget to switch it back on after a flash and never had a problem.
Durasizzle
Oct 3, 2008
134
Stony Plain. Alberta
i ordered a Airdog 2 today, will post up pictures once i receive it and get it installed.
quick question would the airdog have a problem pushing fuel through 3 filters? i have a stock, then a aux. one underneath the hood.
steakman
Diesel Nut...
Aug 31, 2009
69
Barrie, Ontario
bumpedy bump
Durasizzle's got a question.. that I wouldn't mind hearing an answer too as well..?? please..LOL!
I'm lookin to get an AD myself. Also run 2 filters...OEM and a 5 mU as a post OEM.
Thanx,
Theo
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
Depends on the GPH of the filter:)
This is just coming from a sensitive ear Canadian:D
My new pump is quiet and thats the way i like it:hello:
Alligator
Nov 9, 2006
1,919
N. Idaho
I have never installed one with a post secondary filter, but I see absolutely no reason why this pump would have any issue pushing it through another filter. Just FYI, the AD comes with a 3 micron filter.
Dec 2, 2006
1,696
TN
How often should that filter be replaced on the AirDog?
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
Depends alot on you and where you fill up
the AD is going to take the brunt of the cleaning so you will get more life from the stocker:)
Chad ive always ran a pre-filter with the lil KDs and it doesnt really have issues even with being a 90gph pre filter,I am pretty sure the stocker is only 90 gph too
they both restrict fuel a bit......Abby runs 1- 3 micron that flows 350gph:D
Durrasizzle I would at the very least add a lift pump press gauge even if its temporary to see what your press is at at WOT
Are they raycors if so i can tell you what they flow GPH if you give me the model #
