Airdog2 or Fass
ripmf666
15,123
14
47
Wentzville Mo
I just got this info in the mail it might help you out some.
1lowdiesel
<- wish i was there
Sep 18, 2008
1,615
In
they use the same pumps, they get them from the same company.
the FASS was never tested to take the air out of the fuel. it was also never tested to improve the fuel spray. all the pics that FASS had was from the fuel preporator. which was desinged by charlie the father.
i have pages of court transcripts that show that and more.
the AD is hands down quieter than the FASS.
i'll post some comparison pics too
http://www.cumminsforum.com/forum/xtreme-diesel-performance/56082-airdog-fass-comparison-pics.html
Utahski
Oct 20, 2008
546
Northern Utah
Some of those numbers are misleading. The CP3 only runs on about 10-11psi going in. And I believe Casper was going awfully damn fast with a 95GPH pump, maybe still uses that one?
They were both created by the same person. The current AD is supposedly a second generation (improved) version of the FASS. Mine is an AD and I don't think there's enough difference between them to be worth mentioning.
ripmf666
15,123
14
47
Wentzville Mo
Kyle you have any newer pic's .Your pic on the motors do not look the same as the ones I have of both the newer setups.
1lowdiesel
<- wish i was there
Sep 18, 2008
1,615
In
i'll have to check henry. those i got about a year ago.
actually the father designed the first kit that was called the Fuel Preporator. the FASS doesn't remove the air from the fuel.
Fat_Robi
I may be wrong, but...
Sep 7, 2008
Las Vegas, NV / Provo,UT
My airdog saved me today, I was out shooting guns and I was probably lower on fuel than I should have been, going down hill the truck shut down so I coasted to a stop on level ground. with a little cranking and of course the airdog running it fired right back up. Did not even have to pop the hood. sure makes life easier. And next time I will fill up before going into a hilly area.:eek:
dracing70
SH--- GETTING EXPENSIVE!
Jun 12, 2007
1,210
45
mantua, oh
in my opinion the air dog is a much better buy. the installation seems much easier and better explained. as well as the mounting design. also the airdog is hidden much better than the fass and also comes with every item needed for installation unlike the fass that costs considerably more.
z79outlaw
793
Salem WI
Are any of the design flow thru anymore? Is the edelbrock flow thru? Anyone in D-max land running the A1000?
