Airdog 165 died
cwylie
Apr 21, 2011
32
Is it still pulling fuel though the filter is the airdog is not pumping? Im just curious if the motor is not pumping does the fuel bypass the unit all together. I guess Airdog is off today because I keep getting their VM.
cwylie
Apr 21, 2011
32
Yeah I know that but will it still pull it through the airdog filter. If I have the engine fuel filter bypassed am I getting unfiltered fuel?
wodan
Jul 3, 2011
Indeed, it will go through the filters of the airdog, whether it is running or not.
My airdog II motor died after 20k miles... Fuel leaked along the axle of the rotor and locked the electrical connectors inside.
Disassembled it and cleaned it out, replaced filters (prefilled the water separator) and now it is running again.
I noticed the problem by the lack of the sound of a running airdog (duh) and slower throttle response.
Now I tilt the AD a bit so if it leaks again along the motor axle, the fuel would leak at the front instead of
contaminating the rear of the motor where the contacts are...
05chevy3500
Feb 25, 2013
When i had my airdog on my other truck and it stopped working i called them and they sent me a new motor,no question asked ,have you guys called them,,
