hmm Ill have to look into the two front end sensors...I know for a fact in 2004+ trucks there is only one. GM might have changed things in 03 because that was the first year of the passenger sensing system in the light duties, so maybe they did something unique to the HD's that year.
An airbag deployment when a driver is unbelted can be VERY deadly. It can snap your neck quite easilly among other things, crush your ribs etc. Trust me, you are much better off without an airbag deployment if your seatbelt wasnt on. There is a reason all airbag computers in every vehicle monitor whether the driver had their seatbelt on or not.
The dash, steering wheel, and knee panels are all specially designed to absorb impact. If you take off the knee panel you'll see that its hollow with ribs on the back. This is to help absorb the drivers knees in the event that they are in an accident without their seatbelt on. The dash is supposed to do the same thing.
The system worked as it should have, you did survive thankfully, and thats the goal of the SDM. To take into account EVERYTHING (data) its presented with (speed, angle of impact, driver seatbelt usage, TPS, brake pedal usage, G-forces, EFS input) and make an educated decision on whether or not an airbag deployment would be critical in saving the drivers life. If any one of those things is not right, or "all the stars are not aligned" the SDM wont command a deployment.
wear your seatbelt! :
ben
ben
