Air pressure singles vs duals
SmokeShow
6,818
Lawrenceburg, KY
How much different is the setup than when josh had it? I thought he lit a reg. S480 w/ a single cp3 pretty effortlessly? I'd assume a billet 480 would light easier unless you changed exh. housing/wheel too?
I still think the truck is so badass!!!
Sledheadxp800r
That was only my tow tune
Dec 13, 2010
1,151
CT
I pretty much changed everything on the whole truck except for the engine and the manifolds/up pipes
It had a cast S475 on it and it wasn't that easy to light when I got it. The converter was so tight it would drive through the brakes at 900 rpm in 1st gear and 1200 rpm in 2nd gear. 2nd and 3rd gear starts it couldn't spool at all and it took 45 seconds on the start and 75' of track to light in 1st.
The truck does run pretty hard for a stock motor truck and it sounds pretty rediculous
dmaxfireman
'Can do' kind of guy
Apr 8, 2007
2,329
CT
You guys are running really high pressures..... I ran 15-22 in my srw 35's and when i had drw 33's I ran 5-8
Sledheadxp800r
Dec 13, 2010
1,151
CT
My buddy with the gopro is on his way out to scheids so I don't think I'll have the video any time soon
Sledheadxp800r
Dec 13, 2010
1,151
CT
Sledheadxp800r
Dec 13, 2010
1,151
CT
Mounted the trans cooler in the bed Thursday night and Wired up a painless switch panel that wasn't so painless. They has a couple wires backwards and a diode backwards compared to the directions that came with the panel. I've been running 25psi in all 6 tires and its working out pretty good for me.
