Air Dog 150 install
02greysixer
1,829
North Central FL
Depends on who answers the phone there and the mood they're in. Be vague. Don't tell them you're not the original buyer unless they ask and play dumb if they ask about a warranty card.
TWIII
Apr 19, 2015
Well today I went and bought all new filters and cleaned everything. It seems to be working ok now... it the fuse blows again I'll call and try and get a new pump. Thanks for the help guys!
TWIII
Apr 19, 2015
It started blowing fuses again. So I called airdog and they have a new one on the way. Thanks again for all the help guys
bml2200
256
IL
Airdog quit supplying it in the kit. When they did still give it to you I used it but I think people were complaining about the clip coming out and the fuel line spewing fuel under the truck...
Grrrr, yes, that happened to me on my 06. Called AD and complained to which they said there was nothing wrong with the fitting. Figured out that the AD fitting was too shallow so I had to cut off 1/4" off the factory line, after that, no problems.
Bonestock
1,358
Worland Wy
I had airdog replace one the other day. They said they had a run of bad motors for almost a year up until about 6 months ago. They said call them if you have one of the bad ones they have no issue replacing it. This is one of the reasons I like airdog a bit more is the less hassle with warranty issues. They also have a better mounting system location and hose / connections are better. I think I like the fass pumps a bit more but pros / cons with both of them.
