I haven't run into an AD150 kit without quick disconnects yet (since they came out). If you are too lazy to drop the tank and install the supplied draw straw the quick connect will connect right to the factory fitting at the tank for supply to the AD and the line going to the motor will connect to the factory hard line behind the fuel cooler, you would basically just delete the factory flex line. Dropping the tank or pulling the bed really isn't all that hard, then you can install it correctly. Installed one earlier this week, but I do order about 10 at a time and keep them in stock - maybe the next batch I get will be different?
