If your a electrician then you are scary.... 14/2, you crazy? Your going to burn his house down. While 15amp is the BARE minimum think about the continuous duty and continuous starting and stopping. That causes alot of heat. I wouldnt care if its a foot away from the pannel. You still have temperature rise! Thats a ten foot resistor. Wile you may not loose it in voltage drop( you will drop like one volt (that is if you have good power to begin with) so its not drop you have to worry about) and also reading that he is putting it in the rafters or elevated crawl space what is the temperature ten feet above ground in a confined space in the summer? Bet its higher then a hundred..... and you heard you dont have to worry about voltage drop till a hundred feet? Every foot homie. I think you need to take a look at uglys or mike holts website 30 amp breaker, 20 amp wire, and 20 amp switch. Look brother i know im coming off like a dick and hooking this up is small potatos but this is a persons home and i bet like alot of us he/we cant afford to just replace it do to a small mistake. Always go just a little bit bigger as you can afford, its cheap insurance.
I did consider the continuous start stop... Thats the 125% demand factor.
