I am having some issues with my trans after the rebuild. i took it for a test drive and all seemed to be fine, then all of a sudden it was like the trans was in neutral. the engine light came on and i got codes P0872 and P0847. i looked in the book and see the those codes are for valves stuck closed. i dropped the trans pan and found a very little amouth of shavings what looked to me like aluminum. any tips on what i can do to correct this or if i have to pull the trans again. when i built the trans i checked all my clearances and everything was within specs. also the trans seems to chift real hard into reverse and into drive. this is my first allison i have built so i know i am liable to have messed something up
thank you
Mike
thank you
Mike
