Try locking it manually with the scanner.
I locked it manually with scanner and it seems to lockup. I was unable to log and lock with the modus but it sure seemed to lock.
Shot in the dark but the converter won't lock until it hits a certain temp (87.8 F in a stock 2005 tune, for example). Can you log trans fluid temp to be sure you're getting a signal from the sensor? I'm not sure about this one specifically but I know a lot of readings default to the minimum value when they are unplugged or the circuit is interrupted.
" Seems to lock " doesn't tell me anything. If you think it locked, look at the slip rpm and it better be " 0 ". Then you will know it locked.
I was unable to arrow down to the slip rpm once I enabled the lock command. The screen was frozen once the command was entered. It was definetly a positive engagement going thru the gears.
Which solus do you have? If it's a newer one before you start the test you can click on the check mark in the top corner and deselect all pids, then just select the ones you really need to see. If you need more help on pid selection I can take screen shots as I use a solus daily..
If your not on a solus anymore ignore my post
Its actually a Modus. There probably is another way to make this happen other than the way I did it. I went into transmission functional tests and tcc on/off. I selected on and from that point the screen would lock and not let me scroll down to view slip values.
Modis has same functions.. I'd set it up so you only have like 2-3 pids and then you won't have to scroll. Maybe it'll work? I don't have one to try it on to see.
Well I have a strong feeling my converter was the issue of not locking up. I have a very loose converter and while scanning turbine rpm and output shaft rpm there is a minimum of 550 rpm difference. From what I have learned is that no way the converter will ever lock with this rpm difference unless using a lockup controller. I will be sending the converter back in for inspection and re stall. I also will be buying a new converter. Leaning hard on the Goerend R converter at this point.
If I go with the R converter should I have the billet stator or not? I sled pull about 2-3 events a summer.
The R converter has a billet stator.
