So.... Needing some outside advice with this one.
Maybe someone has encountered this or can shed some unseen light.
I've been chasing this issue (after some others) for about a week. Maybe more.... I really want to hear this damn thing run again!
Engine is a full o-haul/build with a Socal AF cam and brand new tested and flowed S&S oversized injectors.
Currently it's in a no-start situation throwing P0202 and P0208 codes.
So as fun as this whole ordeal has been (not so much these last few weeks) and despite less than stellar directions from SoCal, I think I have the whole firing order swap ironed out.
First time around I swapped some pins in the 36 pin connector from the engine side of the harness and the others in the 24 pin from the ECM side. Ended up having to replace a couple female pins and then went back and set everything from one side of the harness (ECM side).
So as I understand it in a nutshell; You only need to switch injector connector (via the control wire) to the appropriate injector for that cylinder for the AF. Which side of the harness this happens from isn't important in reality so long as you swap 2/5, 3/8 and 6/7 and go from the factory order of 12784563 to the AF order of 15634278.
So laid out the firing orders look like this:
the factory cylinder layout
1357
2468
Cylinder layout with the AF swap (this is what its set to now)
1826
5473
I have verified the AF order numerous times with an ohm meter by going from each injector connector to the bails, from the bail to the ECM plug and from the ECM plug back to the injector connector.
Basically pick the injector you want to test, say #8, find the pin in the ecm connector and you should find signal at the injector connector at hole #3.
Inj #2 is found at hole #5, Inj #6 will be found in #7, so on and so on.
All of the connections are showing 0.5 Ohms when tested.
Despite all of this, I still get a P0202 and P0208 codes after cranking for few seconds and the engine will not run. It spits and tries, but won't take off.
i suspect it's because the 2&8 injectors are not firing with the DTCs triggered.
The real kicker is if injectors 2 and 8 are switched in the Alt firing order,
(so it would look like)
1286
5473
there are no DTCs. (happened amongst the confusion by accident)
Soon as I corrected the 2/8 mixup, the DTCs popped up again.
Other things I have checked/covered already:
- I checked all pins via pinout from GMUpfitter.
- I have set and reset the bails and all connectors multiple times.
- All connections have dialectic grease applied.
- All grounds are connected and good (0.5 ohm).
- Voltage is good while cranking (on battery charger).
- Cam and Crank sensors are both getting 5v reference.
- Cam signal coming back fluctuates between 4.99-0.4x while cranking.
- Crank signal goes from 5.01v static to 3.44v steady while cranking.
- Compression check shows 320 - 350 psi which is about right for 16.5:1 pistons. All but cyls 2&4 where checked because of the HS pipe is in. My gauge isn't holding max pressure so it's difficult to be more accurate right now.
- Injectors without DTCs are misting when the engine is turned over with the glow plugs out.
- Logs are showing 6-10psi oil pressure while cranking.
- Logs are showing around 500 rpm when cranking (140-170 when all injectors are disconnected).
- RP is 6-10k while cranking.
- ECM has been refreshed (full cal flash) with both the DSP5 tuning and back to stock. When stock tune is loaded truck cranks smoother and will fire but immediately dies.
- Only other DTCs are for the EGR and Grid heater (both went bye bye and are turned off in the tuning) and an IAT sensor high code. Nothing that would prevent starting though.
- Yes, I have an AF Cam. Least thats what the one SoCal sent and I installed is marked.
I have reached out to SoCal but they're only available via email this last week due to the holiday. They have gotten back to me but the person I've been communicating with is now also stumped. :joker:
So would my assumption is the P0202 and P0208 codes will keep the truck from starting. Am I correct?
What possible causes are there for these codes?
Any idea what could cause them to go away with the firing order incorrect but come back when its set properly? It's an electrical issue, that I am nearly sure about.
*Since originally posting this up on dieselplace last week (and not getting any useful replies) I have tried ice picking the connectors of the two troublesome injectors. No change.
Tonight I swapped the one of the "bad" injectors with a known good one. DTC did not go away. Also injectors both ohmed out at .4-.5 and both had carbon on the tips which shows me they both have had fire in the cylinders.
1357
2468
1826
5473
1286
5473
