Question: Advice Please
2003dmax6701
Aug 20, 2011
41
Texas
I put my injectors in at 150k last year. My Cp3 went out about 2 months again put that in. my trucks at 200k now. Put your clutch in. Your Injector will be fine. Just keep your filter changed.
WTF
slow and broke
Nov 20, 2006
229
Wasco,CA
Well get the clutch done so u can drive if its sliping ur blowing in fuel anyways and my injectors lasted 60k-80k per change
Kspen90
<<<got turbos?
Jul 14, 2011
1,433
Burleson, Tx
Thanks for sharing your experiences fellas, makes me more comfortable runnin it without the lift pump for now:eek: although i cant lie, it will be on my mind every time i start the truck lol
3,733
305
My truck ran no lift pump and an Edge tuner for 210,000 miles on the first set of injectors. Just regular filter changes. This is why I was wondering what you were worried about? As long as you have the factory filter, you're fine. A lift pump only helps hold rail pressure with a big tune, it really won't help extend the life of the injectors. Extra filtration might, and using additives should help.
I now have a lift pump because I kept loosing prime on the factory filter. Eventually, I just removed the fatory filter. Wish I had done that sooner. You'll be fine holding off on the lift pump for a bit.
