Adreanaline Dyno Shelley ID
Utahski
Oct 20, 2008
546
Northern Utah
Certainly not! Just my educated point of view.
Well mr. educated.....most people are aware of altitude. I live at 6500' and know about it very well. And DA at the SLC track will often be 6500' or so during summer. Now do you know what the actual DA was there or are you just running your mouth again?
jacobdewey
This won't last long...
Jan 14, 2011
972
No damn way da was any worse then 5000 yesterday the dyno is normally not that nice
Exactly. They must of had some bad info on temp or baro or something. That's why the dyno is a tuning tool and not a true read of your HP. But we already knew that! lol
jacobdewey
Jan 14, 2011
972
Something was definitely off but hey f you I got 788 dyno says so :D:rofl: :hug:
:spit:
Shut your mouth. I'm going to go run a 13 in my 733hp duramax. Lol. I couldn't care less about the numbers. It all fun to me. I guess my better half got 3rd in the ladies class. Not too shabby for a first timer!
I hope I can make it to the track this year. The lly still has a ways to go before it can make a pass though.
jacobdewey
Jan 14, 2011
972
Hey Jake. On your Print out with all the columns of info, you should have a column that says WhlPwr HP and another that says WhlTrq lbs-ft. Those will have your uncorrected #'s. You should be 595 ish uncorrected. I'm close to 500 average HP. That's a nice curve for me!
jacobdewey
Jan 14, 2011
972
They didn't give me that one?
I c. I asked for an uncorrected printout. They would have been using the same correction factor so 595 would be your uncorrected. We both know your going to be making more than 600hp on the street though. I'd guess my lly to be around 570hp on the street at full 46lbs of boost.
Dave c
Jul 7, 2013
294
Well, since were talking educated i'll give you what i know.
RMR was at 7000' DA yesterday, compared to sea level is HUGE!
Now let me find this place where they dyno'd.
Dave c
Jul 7, 2013
294
Shelly ID is 4633' and yesterdays weather conditions added about 2500'
So DA is approx 7100' DA. :hug:
Utahski
Oct 20, 2008
546
Northern Utah
With forced induction, about 2% per 1000' elevation. Maybe not even that much depending on which source. Get your shit straight....mr educated.
DIESELMAFIAPER.LB7
<----new hotness
Jan 17, 2010
5,163
12
idaho
Ya I know damn well I'm over 650 on the street at 45 lbs and 788x.775 is 610 uncorrected ?? Least that's what I calculated out I'd say it's very easy for you to be 570+ on the street like I said we'll find out when we hit the strip :D
Dave c
Jul 7, 2013
294
So that would be about 14% correction factor.
Sounds about right, BTW forced induction dont change squat, Blown, boosted, or N.A. your STILL injesting bad air! Power production between them is different, but the HP loss % will be similar.
Consider the NHRA pro's, from sea level conditions to Mile high raceway they lose between 3-5 tenths of a second!! This is at the Top level of competition and across the board.
