adjusting driveshaft, pinion angle
Bdsankey
4,180
1,289
Larsen, Wisconsin
Holy crap I never knew there was such crazyness to making sure my driveshaft was at the proper angle. I've just left the truck stock height and let it be.
gmduramax
Shits broke
Jun 12, 2008
4,077
250
Nor cal
So this is what I have now, no preload on the caltracs. Is the upward angle at the transfer case okay? I was thinking I could lower my transmission to get 2* angle at the transfer case and I can add a little preload on the caltracs.
juddski88
Freedom Diesel
Jul 1, 2008
4,656
120
Chesterfield, Mass.
Why would you drive around with preload on the caltracs? That would just amplify any road noise or geartrain noise throughout the chassis, and ride stiff as hell. With those angles you just took, you have vibrations still? How far forward is the slip yoke into the tcase? Ive run a -3deg total like you drew out there before in a lifted truck and have not had any vibration issues with everything else in the system in good condition. On a hard hit to the rear end, though, without setting everything up for a run like at the track, I'd expect to see the pinion roll up 5-7 degrees
gmduramax
Shits broke
Jun 12, 2008
4,077
250
Nor cal
I drive around with my caltracs how I race it. Incase I drive to Mexico one night
I haven’t driven it yet I just wasn’t sure if I could have a upward angle at the transfer case.
juddski88
Freedom Diesel
Jul 1, 2008
4,656
120
Chesterfield, Mass.
Under increasing load, the 1 deg angle will only get slightly better, so that's good, but as the rear suspension unloads it will likely go to 0, which very well could cause a vibration. At the pinion, like stated above in this thread, you want to avoid zeroing the u-joint angle also, so knowing how much it rolls under your applied load is important. I'm assuming that you already checked this too, but make sure the axle perches/shims/center pin are all lined up correctly too. Just 3/8 of a inch out on one side will cause vibrations.
gmduramax
Shits broke
Jun 12, 2008
4,077
250
Nor cal
Ok good to know. I might take a 1/8” out of my transmission mount to put a hair more angle but I should probably drive it first. My driveshaft is now 3/4” away from the crossmember so that’ll be cut out before I drive it. And I’m probably only going to put a hair preload on the caltracs.
OregonDMAX
NOT IN OREGON, NO DURAMAX
Apr 28, 2013
3,964
Goodyear, AZ
I'm lower than that and don't have any issues and adjusted nothing as far as driveshaft angles. Are you sure your vibration isnt from an out of balance driveline or something else being amplified from the angle change.
gmduramax
Shits broke
Jun 12, 2008
4,077
250
Nor cal
I think the fenders on the NBS trucks are higher. My frames cut and I’m going to cut the crossmember out that goes over the driveshaft.
5,847
This with the 6* shim or 3*?
