Adding tension to your dayco tensioner
duramaxzak
Wanna be puller!
Nov 22, 2008
2,431
14
Minnesota
I’ve tried different belts etc new tensioner, belt still likes to jump grooves , it’s still on but that’s only after I dialed back the RPMs 3-400 . I have a brand new belt but it’s almost pointless to put it on until I find a solution to keep it in the grooves. The chewed up one I have on there stays on so I’ve just left it on there . So guys what’s the advantages of running this Billet one from ICT ? Is it adjustable ?
I don't think I or Josh know if the ICT tensioner will work with the Duramax yet, but I was thinking about using one with some kind of rod tensioner. I ordered the ICT billet tension and see if I can come up with a solution...
duramaxzak
Wanna be puller!
Nov 22, 2008
2,431
14
Minnesota
Use something like this with the Billet tensioner to another mount point to keep
tension on belt, no more spring.
prostreeter600
Street rodder
Jul 18, 2010
899
Dallas Tx
Looks Promising. You would be a Hero if you figured a solution for something that has plagued many for as long as I can remember. :thumb:
duramaxzak
Wanna be puller!
Nov 22, 2008
2,431
14
Minnesota
ICT tensioner showed up today, its .400" shorter than a stock Dmax one so I made a spacer for it. Still waiting on rod ends and adjuster sleeve.
With spacer
