I am using an AD150 that I have laying here to replace the stock lift pump on a 7.3 power stroke. They require a min of 55psi at the injection pump inlet. I set the pump at 68psi using a spring from ACE hardware to compensate for the psi drop in the lines and across the stock filter.
Question is, does anyone see any potential problem running this on a daily driver at that psi?
Sent from my ADR6400L using Tapatalk
