ABS issue's
RPM Motorsports
smokinum
May 13, 2008
3,271
10
Central Valley Ca.
The other day my ABS light started coming on/off bud did not feel any issues. The next day sometimes the trucks brakes would feel funny, or pull to the right then be normal.Today the light is staying on and the brakes feel a little stiff. What should I be looking into?
SDP
AKA Dmax15
Dec 20, 2008
261
Port Angeles, WA
I've had the same issue and it was one of the front wheel speed sensors, they're more common on lifted trucks I believe.
2,098
Could be you got some crud in between the sensor and the ring on the hub?
Both my front wheels show ABS codes, but my braking is still "normal". I dont even bother with it.
RENODMAX
Dead Wrong
Mar 4, 2008
3,602
Sometimes lifted trucks have issue because of the rerouting of the sensor. It can get pulled on or messed up. I'd check your wheel bearings and if that doesn't work try the sensors russ
SDP
AKA Dmax15
Dec 20, 2008
261
Port Angeles, WA
That's what I was getting at with mentioning the sensor, just like you said the rerouting with the lift can cause the sensor to somehow get wear and tear.
