2007 2500hd LBZ 150k. I've been having problems with the ac compressor not engaging and running the system. I've put a lot of time in searching for the problem I've check pressure levels vacuumed the system out and recharged found no leaks. Checked all pressure switches fuses relays and ect. I've finally realized that the past 3 times it's rained the system works perfectly all the time until the truck sits and drys out. If anyone has had this problem and could point me in the right direction to maybe fix the problem it would be much appreciated.
Thanks.
Thanks.
