$9000 Build.
Skyhigh4by
Goin to Poochisloose
Apr 13, 2008
408
Powell River, BC
No power windows??? No G-80???
My suggestion before spending any more money on performance would be to take the keys out and switch to 35" tires and go as low as you can with them.
Tank222
Feb 17, 2010
337
Frederick,MD
Maybe it's broke?
The truck came from florida as a special order, guy said he didnt ever put down the windows it was to hot. He ordered the truck for his son so maybe that's why it has no options. Wanted to save some money. It's cool i'll make it my own soon enough.
Tank222
Feb 17, 2010
337
Frederick,MD
1sz - option pkg discount 1wt - silverado wt equipment group:
41u - black 6gl - front spring
7gl - front spring 88b - dark titanium
88i - dark titanium a68 - seat, 60/40 rear folding bench
ae7 - 40/20/40 split bench reclining front seat aj1 - deep tinted glass
am1 - manual lumbar, driver at8 - restraint child provisions
au0 - keyless remote door lock au3 - power door locks with remote keyless entry
bg9 - vinyl floor covering c67 - air conditioning, manual
c6w - gvw rating - 9,200 lbs cmd - assembly plant - flint, mi
df2 - camper style exterior mirrors dk8 - deluxe overhead console
e63 - fleetside body fe9 - 50-state emissions
ft2 - arm tors bar spring adj ft3 - arm tors bar spring adj
gt4 - rear axle - 3.73 ratio jh6 - 4 wheel power disc brakes, hd
jl1 - brake controller k05 - engine block heater
k34 - cruise control k47 - high capacity air cleaner
kc4 - engine oil cooling system kg7 - 125 amp generator
knp - hd aux trans. Cooling system lmm - engine, 6.6l duramax diesel
mw7 - allison 6 speed auto trans nqg - transfer case, manual
nt8 - emission system federal, tier nz3 - full size spare wheel
qb5 - 16" x 6.5" wheels qiz - lt245/75r16/e als bw tires
r6k - processing code r9n - processing code
r9z - poms expedite-sold orders/tse slm - stock orders
t74 - headlamps tuv - battery, dual
u2k - xm satellite radio - service fee extra. 1st 3 months incl. Ue1 - 1yr onstar safe & sound(ask dlr about turn-by-turn nav upgrade)
uj6 - tire pressure monitor uq3 - enhanced audio speakers
us8 - am/fm stereo with cd/mp3 v22 - chrome grille
v73 - statement of vehicle cert.-u.s. /canada v76 - recovery hooks
vb3 - chrome rear bumper vg3 - front bumper
vh9 - envelope owner info manual vr4 - weight distrib. Platform hitch
vt7 - owners manual english vxs - complete vehicle label
x88 - chevrolet conversion yd3 - base axle
yd5 - base front spring yd6 - base rear spring
z82 - hd trailering equipment z85 - heavy duty suspension
ziz - spare tire, lt245/75r16 als bw zy1 - solid paint
Tank222
Feb 17, 2010
337
Frederick,MD
Edge insight is in.
LIft pump is in.
Big Dipper Trans is in.
Idaho Robs dsp5 switch is in.
Power windows are in.
4300k Hid's are in.
Grill and top trim piece are painted black.
Coginto traction bars will be in thursday.
I still need to install the tie rod sleeves and pvc reroute.
I"ll know if i'm switching to 35's in the morning just depends what I can have sooner. Two of my 37's are cut up from a accident and I need them asap and one of my 37's are brand new from 4th of july.
sparepartsracing
spareparts offroad&fab
Mar 17, 2010
773
So I tried to sell my truck with no luck....
Pulled out a bunch of money and started spending.
This all started last week.
Big Dipper Trans is in. Still taking it easy on it letting things break in. Shifts smooth for the most part. You can deffintaly feel the torque converter lock up. Just like my buddies dodge.
Air Dog 165 is in.
Edge insight monitor with pyro gauge is in.
Power windows will be installed on wendsay.
12k Hid's I still need to install these.
Efi live with a dsp5 switch Hopefully that will be installed with in the next couple days.
Pvc reroute and tie rod sleeves were ordered today.
I'm going to order a set of nfab black cab length steps today.
I think that's it so far. My goal is to have a 12 sec truck. I know I need to buy a set of wheels and tires for the track. I'm not sure if pyo's will work with my lift.
you did all of that on 9k?
jmac5058
Nov 16, 2009
22
Tank where did that list of options come from?There is no G-80 the locking rearend (I thought the came on all diesels)but there is no LMM listed and that makes me think mabey its not a complete list.Did you get the list off the door of your glove comparment?Because on my 09 the LMM is on the list with G-80.Do you really hate cranking the windows by hand that much?That must be quite a job labor wise and you must have to buy GM parts also.
Tank222
Feb 17, 2010
337
Frederick,MD
Dude power windows was ****ing horrible. I got this list from a member on one of these sites when I asked for a vin check.
Red
Hating altitude
Aug 23, 2009
138
Colorado Springs
I go all windows down all the time if it's >60 out. I'd hate to open every door and crank when I start/stop driving.
Was your truck on eBay? Think I remember seeing it up there
Tank222
Feb 17, 2010
337
Frederick,MD
Bored so I thought I"d up date this thread.
Truck now has,
8'' Fab-tech Lift Cranked all the way down.
35x13.50 On Bmf 22's.
Recon Head Lights, Tail Lights, 3rd Break Light.
RBP Grill.
Afe Driver Side inter cooler pipe.
RDL 3'' Y Bridge with egr delete tube.
RDL Down Pipe.
68MM Cheetah Turbo.
Next is the 8'' lift need's to come off and I'd like to do a 4-6 NTB drop lift. I think im going to do a set of injectors and maybe a cp3. I also need to buy a set of tires and wheels for the track I keep breaking alot of shit trying to spin these big tires.
Tank222
Feb 17, 2010
337
Frederick,MD
How you like your cheetah???
I like it so far. It sounds pretty bad ass. I have some bug's i'm working out with the truck still, finally found out my dsp5 switch was bad replaced that tonight. I still think my turbo vain position sensor is bad. I'll have to get it cleaned up this week and get some new pictures up.
whitelmmmax
Smaller than stock
Jul 26, 2011
693
lake charles, la
Love/hate it haha. If I would just run 33s or 35s on a wheel with + offset and torsioned it all the way down it would be perfect. I also put some narrow knuckles on it so my front tires are only about 3/4-1 inch wider up front. But even torsioned a lil more than half way and the ride is great and have no problem running 35s with a - offset wheel.
Tank222
Feb 17, 2010
337
Frederick,MD
What about cv angles? I want to buy a 4'' kit and make it ntbd I just really dont wanna spend the money on a coginito kit. But I also want flat angles and a decent ride.
