went to scan the damn thing and it wont read must have a bad fuse for the obd2 or something will try and look in the day light im thinking a .45 might fix this truck or atleast make me feel better
There is a bulletin about the wire harness but its mostly for the 4.8 and 5.3. You have to replace the coil pack wire harnesses. The mass air flow code would suggest false air in the system, vacuum leak, intake leak, we just had one in the shop where the big resonator tank thats hangs off the intake tube was missing!? if you don't have a tune in it get it reflashed at Orilleys with all the latest updates, all you have to do is carry them the pcm and the vin number. Alot cheaper then the dealer.
plugs are delco plat its in intermittent problem and if i strrat hammerin on the truck it goes away and there is no oreilys around here that i know of
I'm talking about the harness on the fuel pump they replace it when you install the new fuel pump. The wiring gets all messed up and losses ground from time to time.
Learn to spell!!!!!!!!!! My 3 year old niece writes better than you! :rofl:Hell I had one issue that bugged the heck out of me. Truck would have power out the ass then would not. Aldo come to a red light or stop sing and it would shut off. Turned out being the cam sensor that goes in from the top at the back of the block. It would make tge volt meter jump and all on the dash along with cel light and fuel gauge up and down.
Truck would also use alot of oil. Dealer changed and checked leaves as I came in and saw how much my 8.1 was using. They replaced the intake gaskets along with a updated part number on the intake bolts. Also found that the 8.1 used less oil when I ran Kendeal.
I doubt it!My 2001 2500HD 8.1 would do this. It drove me nuts scanned it always read fine even fuel pressure. I replaced the rotor cap button
