72mm vvt stock motor setup.
Cknight199
Aug 23, 2012
1,827
Salt Lake City, Utah
The 72mm charger has peak performance from 3500 rpm-4450 rpm, so my question is would it be safe and even possible with stock sticks, to raise my shifting point to 3500 rpm or higher? Will stock injectors even be able to get all the fuel out without commanding crazy timing?
Cknight199
Aug 23, 2012
1,827
Thought only big single like that kinda rpm? I only spin 4000 on mine.
I figured more flow through rpm's is better for me since I don't have injectors and the fuel nor the motor to support this charger to its full potential. So I was wondering if a stock injector/motor could pull off peak hp at 3500-4000 rpm's while keeping the motor happy.
5,818
If your peak HP is falling off at its current rev limiter, raising your shift points wont do you any good
2005LLY
Sep 18, 2011
379
If they are saying you won't benefit from it then why do it? I'm sure you can turn higher rpm.. I turn almost 4k when I'm pulling its a all stock motor.
5,818
So what I'm saying is if I raise my limiter and my shift points will I be able to do that? My limiter now is 3500
you need to discuss that with your tuner, it all depends on how he wrote the tune
again, you wont benifit from it and can actually make the truck slower by doing this if your already falling off peak HP before the shift points.
Cknight199
Aug 23, 2012
1,827
My question is can I raise my rpm's and get my motor to match with the turbos peak rpm or will I just destroy my motor at that high of rpm's on a stock motor and injectors...
SickLL7Crenshaw
Billy The Kid
Mar 10, 2013
1,088
Mexico
You wont blow it up. I had my shift points at 3600 at one point and it lost performance bad i now have them at 3350 and im really happy how it runs.
5,818
and again, you need to discuss this with your tuner.
my question now is, what gain do you feel you will be getting by raising these points to be "within the turbos peak".
5,818
More horsepower. :D quicker spooling with stock sticks
you gotta quick looking for the answers you want to hear and read a bit. since you have dyno numbers, you should have the sheet to show you if you will gain anything. there will be no increase in spool up.
mike diesel
I'm alright.
Sep 6, 2012
4,005
SLC, Utah
I've been down this exact same road before. End result that we discussed is that stock injectors don't have the fuel to effectively push you into the 3500-4000 rpm range. Won't do you any good and I was advised to leave it alone for better results. If you want better spool/more power or "safer" power then you plain and simple need bigger injectors and/or cp3 to support the turbo.
That's why I ended up keeping my 72mm. Adding injectors woke it up big time!
I discussed this all directly with our tuner, he said he has done the exact same thing thinking the results would be similar to what you are looking for. Said the results were nothing like he thought and he went back to previous settings.
j.stanton2009
So Long Space Cowboy...
Aug 18, 2010
97
Climax Tx
I would start saving up for injectors, its gonna take more fuel than the stock sticks (can Safely) put out; to properly spool up that 72mm turbo.
5,818
stock injectors will support 4k shifting easy. mcrat and a few others have already been down that road with success. its keeping rail thats key
j.stanton2009
Aug 18, 2010
97
Climax Tx
You learn something new everyday! I always thought that the larger injectors were ideal for spooling the larger turbos (Without drastic Timing), especially if you have the fuel (Cp3, Lift Pump, ect).
5,818
bigger injectors can help the response of the turbo spooling as well increase the spool up time but you dont HAVE to have them to spool a big turbo.
personally, i want to know how many have tried raising pw in the lower rpm ranges to spool bigger turbos on stock injectors and then made a switch to bigger injectors with the same setup and what they saw for spool up time difference
duramaxftw
07.5 LMM
Jan 14, 2013
Orange, VA
I have a 72MM on my truck and yes, stock injectors are a big fail with this turbo. Getting ready to go with 120 overs and a dual cp3 setup and that will get me where I need to be and then some.
Cknight199
Aug 23, 2012
1,827
Mike diesel did this. Had a 2900 us pulse and went to 30 overs and he said it woke his truck up.
I am fine with my 72 on stock sticks for now :) I'm not in the best financial situation for a built motor so I'm staying with stock sticks for now. But one day I will take this turbo to its full potential :)
