LMM: 72 danville vs others
matt78
Finally boosted launches
Sep 10, 2012
924
texas
I would pm mark on drive pressure. I thought there was an old thread that talked about that. As far as my dp dont no, I dont keep it turned up unless im racing. I was told if you keep the boost under 36 38 it is not that bad, but up in the 40 plus range dp will go up.
NC-smokinlmm
<<<Future tuna killer
May 29, 2011
5,244
388
At Da Beach
I was wondering the same thing. 700-800 hp seems drive would be through the roof?
Things are changing with the tuning on these chargers...;)
I have a buddy with a 750 rwhp LBZ with a 4094 that stays cooler than mine does. I have no clue what the DP is but it can't be that high since the EGT's stay around 1500...
smkndmax05
"Smoked Out"
Feb 17, 2011
479
Indiana
68MM VGT has made a max of 740 HP and the 72mm has made 821..... I was hitting about 62 lbs of drive pressure on my big tune, 40 lbs of boost. My big tune made 678 on the dyno.
matt78
Sep 10, 2012
924
texas
Nice numbers. I know my truck runs 1500 on a pass, and I tow about 10000# , stays below 1250 while towing
PureHybrid
Isuzu Shakes IT
Feb 15, 2012
3,542
526
Central OH
Sounds like Mark has this figured out guys :thumb:
And IMO 60psi of drive isnt bad, hell a stock turbo probably does that much!
MarkBroviak
DMax Junkie
2,151
549
Danville Indiana
I've seen S475's rap a 100psi drive pressure guage so to only see 80psi in an 800+hp vgt setup I'd consider that pretty damn good! There are alot of factors that go into drive pressure production and knowing these factors will greatly affect performance.
ChevyDieselLLY
Whats A Budget???
Apr 1, 2008
2,684
MI, NC, now Hawaii
after watching Mark's video the other day of his truck after he made 890, i wish i would have gone with his 72mm. it really cleans up the smoke so much better then my S472
