beast sunshell
corvette servo
transgo sk-jr kit
friction/steel kit for a 4l65 to get 7 3-4 clutches everything else can stay stock
plug the feed hole in case for 4th acc with a check ball
.072" 2nd feed, .0125" 3rd feed with a .093" band release, and .093" third.
constant pressure mod in valve body so youll only use the tv cable to adjust shift points
make sure the governor bore is immaculate or it will hang and ruin your day
----The parts list I have compiled is below----
1) Beast Sunshell (Amazon FTW)
2) TransGo Shift kit: SK 700-JR
3) Corvette Servo: TransGo 7-2P
4) Constant Pressure kit (comes with self tapper for 4th accumulator): TCI 376021 (early) or TCI 376020 (late)
5) 4L65E rebuild kit: ATP CMS-24 with a Sonnax Kevlar band (7700-01K)
I do have two outstanding questions:
1) What would you recommend for a converter?
2) Would it be better to run the electronic lockup like a TCI 376600 or is it better to go hydraulic like a TransGo 700-LU?
