6L Vortec Problems HELP!!!
LBZ_Duramax
244
North Carolina
www.parrishfire.com
I have a 2005 3500 Savana Van with a Knapheide body on the back. Truck has 170k miles. Problem is we cannot get it to run at 210. If it is over 80* outside it will run hot (Around 240-255) and won't cool off until you get on the interstate for a few miles. We have removed the rad and condenser and cleaned spotless. Also has new GM 4L80E trans, coolant was flushed and replaced. I need this truck for work and it spends alot of time in the city traffic so it running hot isn't an option. I hoped someone on here would have some suggestions.
jlawles2
1,057
Danbury, TX
Electric fans or belt driven?
You check to see if the thermostat is good?
How about checking the fan clutch?
Also check to see if the exhaust has a restriction. I.E. Cat plugged will cause strange issues.
jlawles2
1,057
Danbury, TX
Might try Flex-a-lite (probably spelled wrong). They make a bunch of conversions.
Might try looking at the exhaust system to see if it has a hot spot around the converter.
Also check the timing. I saw an old school that was running the timing way off and it overheated, and made the exhaust manifolds glow. I know that the timing is computer controlled, but may want to shoot it with a timing light to see if it looks close.
LBZ_Duramax
244
North Carolina
www.parrishfire.com
I will try Flexalite in the AM. I am at a loss on this thing. What do you think about the water pump? Looks to have been changed before but don't know how long ago. I bought the truck off a bankruptcy sale. Is there a chance the pump is not pumping enough water? I was under the impression that WP were either all or nothing.
Js95gt
Dec 4, 2010
53
Walker, LA
There are two air bleed hoses that feed the surge tank air. One is from the radiator and the other is from the throttle body. Check both ends of these hoses for a flow restrictor. If the restrictor is stopped up it will overheat due to an air bubble getting stuck.
duramaxxx06
Aug 11, 2009
177
jasper tn
check the vaccum on the engine to see if the cat is plugged. i have been having problems with my jeep doin the same thing and i am beginning to thinks its just too damn hot outside cause ive changed just about all the cooling components. and as far as spinning the impeller i have not heard of anything like that. may wanna check gm fulsize forum.
duratothemax
<--- slippery roads
Aug 28, 2006
7,139
Wyoming
electric fan is not the solution. Thats just a ghetto band-aid.
If everything is working properly in the engine, there is no reason the stock fan would not be sufficient to keep it cool.
Fix the root problem, whatever it may be, and you wont have to go messing around with a confusing electric fan conversion that might not even fix the problem...
Ben
THEFERMANATOR
LEGALLY INSANE
Feb 16, 2009
3,890
ZEPHYRHILLS, FL
Have you tried another coolant temp sensor? The dash guage and ECM both read off the same sensor in the engine, and if it is bad it can read hot and actually not be hot. Have you verified with an infra red gun to see what it is actually running for temp? Without knowing the actual engine temp you can't know if it is running hot or not.
duramaxxx06
Aug 11, 2009
177
jasper tn
Ben
:roflmao: :thumb:
C.C.Reed
May 1, 2008
91
Quick question. . . when you say "cleaned spotless", was the radiator taken to a shop and cleaned internally or just have the fins cleaned out? I would lean towards the core passages being blocked with crap.
