6500lb in bed?
MadMaxx61
Devilmaxx
Oct 13, 2008
5,458
Windsor, Ont, Canada
lol been there done that the F-150 was shot after I did it too.
over 5,500lbs in a F-150 4x4 bent the real axle and frame all to shit. I had to put the truck in 4x4 to get it to move.
Mind you it was a 94
ecc_33
Junior Member
Aug 10, 2006
1,925
Amanda, Ohio
should be fine at low speed. I will try anything once lol. Only thing I would be worried about is tires. but if its slow than shit :thumb: it will ride
Fingers
Village Idiot
1,715
86
White Oak, PA
The axle will handle it fine. The stock suspension will be near, if not bottomed out. The tires.....that's another story.
Stock, there is about 3000# on the rear tires empty. (varies with bed/cab combos)
Stock tires at 3000# each will be running at 200% rating. Not good.
I, for instance, have tires rated at 3800# each. So I would be running at 140%. Not good, but would be tolerable in a pinch.
Dually tires run at about 2500# each X 4 or 10,000#. Minus truck, 7000# to work with.
RKTMech
Idiot with a wrench
Aug 18, 2008
936
The Norco's
I'll fix it....... ol'Blue can do anything! What else are great stories made of! See you this afternoon....
Kat
Wicked Witch of the West
Aug 2, 2006
17,899
13
60
Norco, CA
Blue must be OK... He just came home and swapped trucks and told me I could drive Blue to closing ceremonies for softball if I wanted to.
JD Dave
In way over my head
May 19, 2008
2,388
Caledon, Ontario
You will be fine. We have had single rear wheel salt trucks carry over 5000 lbs and drive all over the place with them. We also have a dually 3500 that scaled 11000 lbs payload of salt and my dad actually drove it to breakfast. That truck has been a salt only truck since 2001 and carries over 8000 lbs regulary. I wouldn't even think twice about doing what your doing. All that being said we have 2 33k trucks now and we don't use pickups.
dmaxfireman
'Can do' kind of guy
Apr 8, 2007
2,329
CT
i want some pictures! i loaded my truck with topsoil up level with the top of the cab once.... no idea what that weight but i drove over 30 miles with it i say go for it! :thumb:
5,818
we use to haul 6k worth of sand on two pallets in the back of our old 93 ex/lb 3500 srw to get it to our plant. Was all we had at the time to get sand and we'd haul it 15 miles to the plant. suspension would almsot be on bumpstops but the truck never gave us an issue. did that for 5 years hauling sand once a month
Gasuout
Johnny
Mar 20, 2008
2,188
Santa Ana , Ca.
Maybe a 1/2 or 3/4 inch sheet of plywood to help disperse the weight on the sheetmetal bed . I think the suspension will be fine bottomed out for 3 miles .
Blue is a diehard ..... :thumb:
McRat
Diesel Hotrodder
Aug 2, 2006
11,249
Norco CA
www.mcratracing.com
There are 2 CMM's that are not functioning that I must move. The heaviest is about 6500, the other about 5000lb. I could pay $2000 to move them, or move them myself. The reason these are heavy is because they have a very thick granite slab for their base, and an iron superstructure. They don't look heavy but they are.
If I decide to just use Blue, I'll take pics. I might wuss out and use a trailer though.
doug9940
Ca LLY
Dec 6, 2009
391
56
Corona, Ca.
Sounds like your moving into the new shop today. Let me know if you need a hand. I'm not doing anything else this rainy day.:thumb:
