60' questions.
gmduramax
Shits broke
Jun 12, 2008
4,072
248
Nor cal
Tire pressure will help a lot. Remember tire pressure when the truck is sitting in the pits means nothing. One of the big reasons people get wheel hop (if already have some sort of traction bars) is front to back tire pressure.
So many people run higher pressure in the front than the back, why? Because it looks right when the truck is sitting still, this is wrong. You have already lost by creating a poor front to rear gear ratio. When the truck launches the rears take a lot of the hit, basically reducing the diameter. The front lifts and the front tire now expands, increasing the diameter. Thus you have created two different gear ratios. The fronts now have to spin or break the t-case. Once the fronts spin, the rears have to follow and you have created a bouncing hobbie horse.
With stiff/short side wall tires, I would recommend trying equal psi to start and work the opposite of what most will tell you. Go-Pros will tell you a lot if you hook one up to see the tires during a run.
Also don't deny physics by trying to stop weight travel. Make it work in your favor. You have 4 tires on the ground, racers should give this some thought. Once you start picking up the front tire, then new tactics will need to be applied.
The height of the tire changes but the circumference is still the same. I don't see how it affects gear ratio.
IdahoRob
Jun 5, 2007
1,151
I don't worry about circumference, I worry about the radius of the center of the axle to the track. Try pushing a rear axle with a lower psi tire on one side and see what happens. Overall circumference is close to the same but radius from axle to the ground is not, making the ratio different thus pulling the axle in a circle. Just my opinion.
Burn Down
Sep 14, 2008
7,092
Boise Idaho
Interesting, I will have to experiment with my air pressures more next time I get to the track. I was always told to run the rears less than the front, usually was only a few pounds difference though...
gmduramax
Shits broke
Jun 12, 2008
4,072
248
Nor cal
I usually run my rears close to the fronts but I'm curious if I deflated both my back tires and drove straight if the tires would bind up.
yamaha537
May 26, 2011
56
New Jersey
This past weekend I tried 20r 25f with 420s and the front end still danced around pretty hard. Tried 32 all around weeks ago. Same thing, pretty hard hopping.
Moneywellspent
Dec 27, 2013
236
Idaho
10pounds is about all I can get before it really gets hairy. Sleeves and DHD brace. T bolts out and it have 2" drop shackles in the rear.
At Irwindale I ran a 7.7 with 28 psi up front and 32 out back. I have 22s though and my ranchos set at 9.. But on a non prepped track I can cut 7.9 full weight with 42 psi on all 4 corners and my ranchos have to be set at 5 in the rear. Next race day I'm going to try to lower my tire pressure to 34 out back and see if I can get a 7.8
So far I'm very happy because I can hit 7.9 all day on a no prep track
yamaha537
May 26, 2011
56
New Jersey
Anything for axle wrap?
Traction bars out back
What's your set up? I pretty consistently run 7.6 @88 -89 Just can't get the 60' to make up some time on the big end.
Moneywellspent
Dec 27, 2013
236
Idaho
Caltracs, ranchos, overloads removed, 3" lowering shackles, and that's it for suspension.
I usually cut 1.8 60' the 7.7 was with a 1.7 60' which isn't bad considering I just have a billet 75 and stock fueling.
Verlon at ATP
Mar 19, 2015
165
I ran toyo proxes st1's for a long time. This is with a full kryptonite front end, rancho 9000's, cal trac's, and spring clamps. I could never cut a consistent 60 foot to save my life. Tried all sorts of tire pressures. So I finally got a deal on some drag radials and read up on caltrac tuning and I can now cut a low 1.6 every time in my 7500lb whale. If I could get my converter to stall a little higher it would go high 1.5's
I run my pressures equal between the front and the rear. The caltracs are setup up with an 1/8th inch or so of space between the pin and the leaf with the bar in the top hole. I also no longer run spring clamps. Ever since running this way, the truck leaves dead consistent unless the track is total crap.
yamaha537
May 26, 2011
56
New Jersey
I might throw stock wheels on the truck this weekend and try again. I think maybe the big offset on my 20s are pulling the front end around a bit. Not sure if anyone can see it in the video but it squats pretty hard and that's when the front wheels start to toe in and out
Sorry to the OP I'm not trying to jack your thread. Just gathering information to help us both hopefully.
Antiher03
Nov 10, 2013
165
Utah
My 60' are shit.. I was told to try more psi up front but it hopped like crazy. The last I ran seemed to launch awesome! I was maybe 2 or 3 psi less up front but I was scared to launch any harder.
