60% overs with a danville 2.5 turbo?
KTOG
May 2, 2013
40
Thinking about going with this setup for my off season pulling mods. Stock motor as far as internals. Looking for make 600 hp just for pulling and daily drive it around 400hp. Does anyone have videos of them pulling with close to the same mods?
Thanks
catman3126
Ehhh?.... You don't say?
Jul 24, 2012
2,636
NE Oregon
should be pretty easy with those. 550 600 can be made with stock fuel and a turbo but injectors would make it easier and easier on you stock LBZ pistons.
KTOG
May 2, 2013
40
That's what I have been told, that's why I went Injectors until I can build the motor. Might even do a pump to make sure it holds the right rail pressure.
jkholder09
Jan 8, 2012
1,188
Maryland
Sounds like a good setup.
Get manifolds and uppipes in the process. All 3" ic piping you will be over 600 no sweat.
from mobile
catman3126
Jul 24, 2012
2,636
NE Oregon
Over 600 rwhp with stock pump and injectors so I don't think I'd even worry about a pump unless you just want to do one
KTOG
May 2, 2013
40
Thanks for the information. I don't won't to push it over 600 with the stock motor.
Dozerdog74
Lost Cause
Sep 13, 2012
101
Montgomery, IN
I don't blame you..I didn't either in the beginning but now I don't care. It seems to be hit or miss on them if they handle it or not. Mark doesn't have my tq coming on until over 3500 rpm.
Dozerdog74
Lost Cause
Sep 13, 2012
101
Montgomery, IN
This is my second year. IMO as long as you don't beat on it on the street to hard they can luve awhile at this level. I'm on an lly bottom end. I pretty sure Mark made 821 on lbz bottom end. Guys have bent rods at a lot less then me in fact I'm pretty sure mine are short now but it still runs dang good.
WI Huck
Where does the time go?
Feb 8, 2012
137
The key part of the setup is the tuning. Mark @ Danville is an excellent choice. :thumb:
