LML 6 Speed Limits/mods
15,681
Your existing performance converters won't work in the new trans? Or is the converter apply hardware in the trans the problem.
The converters will interchange just fine. The problem is the low end throttle response of the LML. The aftermarket converters make the problem worse.
I can increase the converter charge and give it more low end TQ along with some TCM work and see what happens.
D-MAX Mafia
Hood down, smoke up!
Nov 4, 2009
1,112
13
Phoenix
To the op, I have the Quadzilla 80hp delete tune on my LML. No problems shifting, no codes and getting 20 mpg. It rips pretty good for the few mods I have. I just changed the spin on for the first time and there was a light film on the magnet.
I need to go back to the track and see what I picked up in the 1/4.
turbojamie
101
My piece of shit wont even shift at wot and a new filter on the light tow setting. Anyone know if the ppe fuel rail shim would bump it enough to work. Sucks when your puttin the clinic on some ford and hit 100 km and it falls on its face!
jc1843
Sep 27, 2009
228
86
So Calf
Check the rubber fuel lines by the firewall on the driver's side. They collapse and restricy fuel. Lift pump will help.
