Why not put a stock piston in C2 with 8 frictions?
Hmm, interesting.
So, you said you could get a good 6 speed parts trans for $450? Seems like that's not a bad deal to potentially fix your problem, as well as giving an input assembly that fixes many of the drawbacks of the 5 speed assembly. I'm sure it's a lot cheaper than the parts would be new...
Just got the C1 snap ring on :woott:
I'd like to hear that the Transgo modifications which I just performed have been successful for others
Or should I revisit the C2 at this point...
They seem to work fine for most, but mine isn't most I guess. I would imagine you'll be fine, if not taking ito ut the second time is alot easier(seriously though don't sweat it, I think mine has underlying issues and I'm REALLY picky).
They charge me $450 on top of the $1500 if I don't have a core is what they wanted.
Ahh, that sucks. Here you could buy a core for $400. Ask your yards if they have returned cores that they would sell you for the core fee...
I've tried that and they say we have contracts with our core buyers that says we have to sell them to them. Basically they just want to get me for over $2K instead of the $500 for a core.
Did you consider that C3 might be hanging up?
Just a thought.
Matching C2 piston to sealing ring style makes a difference.
Allison parts catalog PC3062EN, Service Information Letter (SIL) section SIL 41-45 tells all about the C2 piston/sealing ring type. Early 01-02s with C2 piston #29538342 (with .060" bleed hole in the bottom) used butt joint sealing rings #29538212. Later 03+ used piston #29539653 (bleed hole ELIMINATED) used double lap joint sealing rings #2953894. In the Description of Change column it states: "Improves consistency of C2 fill volumes".
Hope this helps
We just discussed this the other day my friend.
