6.7 Cummins rail plug problem
coker6303
Keep Calm and Chive On!!
Aug 6, 2009
2,484
40
Houston, TX
Ya, wrong spot but I need clarification. Ultimately it is identical to the dmax with the high pressure rail and relief plug.
Here's what's going on, I installed an MP8 on my bro's 2011 Cummins and even with an AD165 it throws a low rail pressure code. Truck is stock with just the MP8. Could it be spiking psi past the shimmed relief setting and then dropping rail pressure? What's the typical case? I'm confusing myself by over thinking the situation...
Sent from my ADR6400L using Tapatalk
coker6303
Aug 6, 2009
2,484
40
Houston, TX
I used all 3 shims like the kit called for on the Cummins. Going to just pull it off when his H&S black maxx gets here. 30kpsi isn't healthy
08 LMM Duramax
Relentless Diesel trans
JoshH custom tuning
554hp 1014ft-lbs 7/30/2011
13,715
779
Are you sure it's even leaking at the plug?
BTW, you don't have an relatives around here named Dustin, do you?
coker6303
Aug 6, 2009
2,484
40
Houston, TX
I'm ASSuming its leaking at the plug. Not 100% sure
Nope, no relatives up there that I know of. May be related, but I don't know them. But if they are rich, I might be new found family!!
08 LMM Duramax
JoshH custom tuning
