Help: 6.5 guy here needs help
2wd_Sled_Puller
Heavy Equiment mechanic
Feb 19, 2008
1,356
Florida
I have a 1997 6.5 here and i can not get it to run. The truck will fire up then when it gets warm shut down. if i wait for it to cool it will fire right back up then when it gets warm it will shut down. It sounds like it something electrico. And help will be appericated
tommystunes
May 8, 2008
have you changed the pump mounted driver,checked lift pump,or made sure fuel is getting to injectors
Alberta Redneck
Apr 29, 2008
Fuel is not getting to the injectiors when motor is hot. Lift pump is still pumping fuel. What could this be??
Sounds like your PMD or FSD. Call up heath diesel and order his PMD Isolator.
The stock one is mounted to the IP, but the heat in the engine valley kills the PMD.
2wd_Sled_Puller
Feb 19, 2008
1,356
Florida
Hey man thanks alot i will call heath diesel first thing monday and see what we can get it to do.
Thanks Again
