59 Apache Duramax
rfletes79
649
174
Galt, Ca 95632
It’s a factory 59 frame. Ic is an eBay special. We haven’t made the thermostat housing yet but yes it will be facing forward like the Chevelle. I may end up purchasing an HSP as theirs is already made. We’ll see, since we missed hot August nights the build slowed way down. I’ll try and get it going by the end of this month. We’ll see.
rfletes79
649
174
Galt, Ca 95632
Charred wood, navy blue looks legit!! Thx dozerboy!!
Deny
Oct 30, 2016
23
awsome job see your cooler is in front off rad are you going to use a push fan? should a guy build a shroud or just put fan right on rad .. dont know how you got that in so tight but good job looks nice and clean
rfletes79
649
174
Galt, Ca 95632
Yes the fan is a pusher and is mounted to the condenser in front of the radiator.
Got a few more items this month installed. Condenser, fan, booster/master, pedals, T stat housing with hose and some more work on the fuel system. Hopefully be driving sooner then later.
Deny
Oct 30, 2016
23
hi rfletes 79 i am also building a 55 chevy truck and was thinking on puting all the computers in the cab behind the seat in an enclosed area. Was wondering if they will get hot in there ?? How much heat do they put out ?? When it was in the truck one of them gets air from the rad shroud so imagine thats to cool it off. Where are you putting your and where are they on your Chevel ??? Thanks Denis
rfletes79
649
174
Galt, Ca 95632
If you look further back in this thread you could see where I mounted them on the back Wall behind the seat. I’ve never noticed them making any heat whatsoever. As far as the Chevelle goes the ECM is currently mounted on the firewall behind the driver side inner fender. I have never had an issue with it.
rfletes79
649
174
Galt, Ca 95632
Latest progress. Been busy with work and the chevelle so haven’t touched her since October.
All the fluids are in and it runs with a hot wire and push button. Also got the steering situated, column, steering rods, u joints and support. Brakes all hooked up and bled. Fitting the seat in now, pretty sure I found one that fits well. Just need to make brackets and get some belts for it.
