I use the hot+2 on my 03 I want to get around 500+ hp with the stock rods studs and turbo. I see a lot of you run EFI live, does anyone run TTS tuning. Can I get this with tuning alone. What should I do.
Efi live is the way to go
wouldnt the turbo give away before the pistons could ever get hot enough. I thought the stock rods were good up to about 575 before they would bend, or break. I am just not sold on EFI live tune yet Shane I have yet to see it in action. You have a built motor, I need to see it on a truck in my class. I'm unsure what I would realy gain with it and I worry about my crank also. I got to go clean up my truck check back later.
Yes but don't expect your stock rods to hold that long plus the high egt's will most likely take out your pistons. The efi & ppe should get you there
you should definetly worry about the egt's more than anything else
x4...no idea how much rwhp I have but my truck at almost 7300lbs went 12.73 in the 1/4 so I'd say somewhere around 550 and I still get 22-24mpg on the freeway..thanks EFILive
He's not running a LBZ. He has the good pistons, you know the ones you guys use when you build your motors...
I ran an 8.40 on a slick track last time out I not sure what it will do on a good track or the 1/4. On the EFI how do you realy no just how much more power you are geting. I am used to set tunes. I looked at TTS website and it give rwhp and I dont think that it is much more if any than my ppe and it is 1200 bucks.
