If you hold the driver's side tire and spin the drive shaft, does the passenger's side tire turn?Driver side one does yeah.
How did you do that?
What made you think the 4wd didn't work in the first place?
I went to use my 4wd and it didn't work when I needed it.
I just used the handle of my ratchet and pushed it in. The fork should automatically disengage when you let the pressure off of it.
You could have a bad shift fork inside the transfer case. they are known to have wear issues.
Not really a smack, but a few taps and it came loose. It was just sticky enough that the actuator couldn't push it in. I also changed the oil at that time and put in 75-90 synthetic.
I thought you said the Driveshaft doesn't even spin? If that's the case, your front diff is fine. Take the selector motor off the transfercase and check the fork operation
There's nothing to worry about in the front diff at your power level. Sometimes the slide collar doesn't fully engage or shatters anyways under high load/use/HP conditions.
Not really wear, just see if it is sticking
If it had no fluid, look up pump rub. Its a known common problem.
If it was replaced, look up a rub kit and swap over to 30wt motor oil.
I would do pump rub kit regardless if u have warranty or not. It may not have an issue till 3.5 yrs from now and then your lookin for a new case cause it ate a hole in it.
