Now you guys get to poke fun some more. Been banging my head on this one for awhile. I've tried 2 different shallow pan filters, new bell housing gaskets gm part # 29536478 and 29540130 and finally a new pump. Still no line pressure at port, and fluid doesn't pull down off of dipstick. P0701 code.
Bolt holes will line up even if gaskets are crossed. The gasket with the big hole goes on last up against the trans case. Your pump has transferred metal but will still make pressure. Make sure your stator shaft didn't twist around or work its way out of the stator body.
And no one is making fun of you. We are just trying to help.
So if I turned trans over on its back, poured oil in filter hole, put a handle
In converter and spun it should squirt oil out ? Would be nice to check before I put back in truck again
All the stator valves are free moving and came right out. I hate to do this without finding a problem but looks like I'm gunna have to find a new stator, pump, and comverter housing.
Wrong way to do this. There is nothing wrong with the bell housing. Was anything changed in the pump assembly?
