Who's convertors /brand you been running
I had been using precision
It was a tripple disc. My trans runs between 160-180 depending on traffic
Soemthing doesn't sound right as the triple disc I believe is based off of the same converter that the ALLISON uses. And there is plenty of guys out there running 4 digit HP through the PI converters with an ALLISON. Are you sure your not getting an AFL circuit issue or a pump pressure problem?
So the coverter is the week link? Or so it seams
That's what it seems
Are you still using PWM on the converter clutch engagement?
I find it hard to believe that a triple disc converter from PI would let loose behind the 4L85E when it is teh same basic converter that goes behind the ALLISON at well over 1000HP. Sounds to me like you have something else causing it to let loose to me.
