All parts inside were upgraded that needed to be. The 4l85 had the HD sprag and drun and the hardened input shaft already.
I can only guess because mine puts down more rwhp than double your flywheel power. The 1st thing to go was the converter in each case.
I am not against the 4l85 but at this point if the 6spd ally is an option I will go that route
at most im doing is ~300fw.. i do have 4.63:1 gears vs 3.73? that you have..
eveyone i talked to stays a stock 85 can handle 500-550tq and i have done my best to keep it under that.. WOT for 9 miles up 5-6% and it holds..
im guesing your runing a decent tune that would prob limp a stock 6 speed?
what actually is slipping first? TCC? OD/OR clutch pack? direct, forward, intermediate clutches?
i ask cause i havent seen any one come forth and say what went wrong in their tranny.. mike L has said many times the od/or clutches are weak link.. but i havent seen anyone post up burnt od/or clutch packs or say that was their problem..
hughes make a billet both single and tripple disc xfm convertors..
i want to be able to drop down to 4.10 or 4.30 gears but to keep my 65mph on a 5% grade @ 26k im going to need ~400fwhp
also notice our driving style most likely are completely different guesing you work out of your van much like i work out of my truck.. taking that my fuel cost is probaly higher % over the over then your is.. that be correct?
